Ferguson to-30
Hello out there, I needed to remove my rocker arm on my to-30 and at first glance was a bit stumped on how to remove it. After searching for a while I modified an idea I saw and came up with this. It is a 3/4in bolt (8in long) and 2 nuts. All grade 8. I shaved the nuts down to the size of the bushing and smoothed them of burs. Slide the bolt thru the right side hole, then screw on both nuts, snug the nuts, next take a 6lb sledge and smack the bushing out. This keeps u from having to hit the bushing to the right and having to cut it with a torch to remove it. To reinstall put the nuts further down on the bolt and the threads will hold the bushing while u drive it in. Hope this might help someone.
