Going back to an earlier thread. Here is
why it's darn near impossible to adjust a
valve with a worn rocker. One pic is with
the indentation of the valve worn into
it.I don't care what anyone says this
won't adjust properly. The other pic is of
the same arm after I ground it on my Sioux
valve grinder with the rocker adapter
mounted.
Some of you on here think you might be
smarter than everyone else and are quick
to dismiss any ideas. I might be a
novice(only 30 years experience) but I
have learned a thing or two. About 29
years ago when I was adjusting the valves
to spec, I rocked them back and forth and
could easily tell there was more play than
there should have been. So I got a dial
gauge mounted up and took an actual
measurent and sure enough there was about
double what was supposed to be there.
At that point I didn't have the equipment
I have now, so I found a local guy to
grind them for me. That got me on the path
of machining and learning how to rebuild
an engine properly. That being said I'm
not the best machinest or mechanic in the
world, but I do have guys driving stuff to
me from 4 plus hours away. Hopefully
someone can learn something from this as I
learn new stuff from sites like this
everyday. Let the bashing begin.
mounted.
