Rocker mis-alignment with valve stems
I am rebuilding a 172 diesel engine for an 841 Powermaster. When putting on the rocker arm, I noticed that some of the rockers don't line up real well with the valve stems. I didn't disassemble the rocker arm, and I put it back on the same head it came off of. I have enclosed a picture of the worst case.Is this a problem? If so, what is the fix?
Thanks.
Is there another one that is misaligned the opposite as in looking at it from that side of the tractor it is off center of the valve to the left? If so maybe those two need to be swapped. I see the oil supply tube comes into that rocker shaft stand maybe there is a special offset rocker that goes in that position that has been overlooked during a past replacement.
There are 4 that are off to one side, 3 that are off to the other and 1 that is pretty good. I looked at similar rocker arms on EBAY and the wear on some of the rocker pads show that they weren't very well aligned either. I hesitate to take the rocker arm apart as I noticed that the supports are very tight on the tube and I don't want to damage the areas where the rockers rotate.
I am not sure if it is the picture angle, but looks like you need to swap the 2 in the picture. they are both off to center.
I'm guessing you didn't pay attention to see what things looked like when you first took the valve cover off to tear the engine down, right? So you wouldn't know if it was like that before.
Since you didn't take the rocker shaft apart, it had to have been like that when you got the tractor.
Parts catalog shows 8 identical rocker arms.
If you were to rearrange or shim the rocker arms they would, for sure, need to have the tips that contact the valves "refaced'.
Parts link
You may not have switched them but a previous owner/rebuilder may have. The one on the right appears to have less shoulder on the left side and would set even on top of the valve if moved to the left position. I've had to deal with this on a head before and had to do a match game.
Is there anything to center the shaft stand to the pad on the head? Possibly a dowel or alignment ring missing?
That cover stud looks kinda rough too...
They have been that way for 60 years or so. I can go take rocker covers off 4 172s, 3 223 6 cyls, 6 Y blocks and couple 201 3 cyls and there will be several miss alined. They all were run that way for years and some are still running that way today.
When we bought our Farmall C 12 years ago I was checking the valves and found the same thing! I pulled the rocker shaft and put spacer washers in the appropriate places to align the rockers to the valves. I suppose I should check the valves again now that there worn in to a different spot. But it's been running fine and quiet ever since.
