Rocker pin removal?
Dr_Rockwell14
1940 Ford 9n
Hello, im just trying to confirm that the long lower pin on the rocker can be removed? Im trying to add stay chains for a brushhog and that pin is giving me a fit.
And, being a long pin, might even have a joint in the middle, to "bend" it to clear the left side fender when removing it! More places for rust to bind it up. Good luck. You will probably need the blue wrench and a lot of band-aids, and no children around! zuhnc
Unless you have some other reason to remove the long pin, why not get a 6" pin for the toplink to rocker and connect the stay chains there?
That is only option fpr those with late 49-52 models unless they fabricate something.
