rocker shaft 706..263
spooky
there is no oil getting to the rocker shaft and tappets. Have 32 lbs.of oil pressure. Could some jump in and give some ideas what to look for? help!!
yes that is right...did not put in cam bearing... guess that was a no no.so does it get oil from front cam bearing?
checking with engine running and valve cover off. I was oiling good about 40 to 50 hrs. ago but not now!
Need to invest in a shop manual that has an oil diagram.
Being that it was oiling and has now stopped, chances are a bearing may have spun and shut off the supply. But it could also just be a clogged passage.
Without knowing how the oil gets to the shaft, just guessing can get expensive!
