thicker bearings are OVERSIZE they make up the distance when grinding the crank down to make it round again so you have a crank 10 under you will need OVERSIZE and thicker bearings. 10 under means the crank has been ground 10 thous then comes the thicker bearings 10 OVER to fill the void
(quoted from post at 13:50:29 03/16/19) The bearing you have is call a (oversized) bearing because your crankshaft is (under sized) (worn) by .001 . I use to grind crankshafts back
in the 80s .
(quoted from post at 10:34:20 03/16/19)(quoted from post at 13:50:29 03/16/19) The bearing you have is call a (oversized) bearing because your crankshaft is (under sized) (worn) by .001 . I use to grind crankshafts back
in the 80s .
I'm really surprised!
Even Federal-Mogul refers to them as undersized.
