Rod bolt tightening
Anonymous-0
When the rod bolts have been torqued right and the hole on the bolt is between the holes on the bolt, do you back off or tighten alittle more to line the holes up? Also how much do you torque manifold bolts? Thanks. Harold
YA torque them down and leave them . You must be talking about the safety wire holes ya live with where there at . and as for the manifold torque on what tractor , knowing this will helps us as we have no idea just what your working on.
I have also swapped the nuts around to try and get them to tighten up closer and always go tighter not looser to align them.
Make sure you have the right bolts for the manifold. Too long a bolt will bottom out and crack the manifold. I used to work in a engine plant, we made about 200 manifolds a month for service - pretty much all due to somebody usuing the wrong bolt.
Thanks for the replies. I stopped at a machine shop today and asked them what they do. Said 1/12 of a turn and that would only increase the torque pounds 3 pounds.
