roosa master jbd633
Rebuilt this injection pump the flex ring was down. Cleaned it up nicely put it back together and installed. Can not get the RPM"s to change, runs around 1200-1500 throttle doesn"t seem to change when moved Unsure if I got the weights back together right on the governor! Pump loads up unless i crack the timing window to relieve pressure Help!
My first pump rebuild not to bad just unsure were to go from here.
What manual would I need for this pump (TM1109?)
