Bill -- Banquete TX
Hi y'all. I have taken on a job of pulling some huisache stumps for a neighbor. I've been using a single middlebuster with a chisel plow sweep on the end of it to get most of the small ones. The bigger ones are 4-5 inches diameter and I'm pulling out 3 feet of tap root on some of them. Pretty good size critters. Problem I'm having is that even with the wide chisel plow sweep the plow is wanting to slide off the stumps and slip past 'em, making each one a 5-10 minute job not to mention the side shear on the 3 pt, which may not hurt but can't be doing it any good.
Anyone got a 2 ft or so root plow who could snap some pics and give me a little guidance on it? I don't really have to get any deeper than about 6-9 inches, and a couple feet wide would make it plenty easy to hit each one. I don't have to do the field wall-to-wall, but I do have about 40-50 more of them to pull up.
I was thinking about two shanks vertical, with something welded across between them on about the same angle as a buster point, whatever that would be.... like about 30 degrees? A piece of inch by 4 inch, beveled or "sharpened" on the front... will that dig enough to keep it in the ground?
Two things need to happen: I need it to dig, so it'll stay in the ground, and I need it strong enough to not bend when it grabs ahold of a root. When I've hit the few I've hit square on enough to pull out with one pass, it's not enough resistance to lug the 3010LP down at all.
Thanks, and if there's anything I missed mentioning, tell me and I'll add on tomorrow morning.
Bill
Bill
