Rosa master fuel pump
saddltramp
I have a 1960 871 SOS diesel tractor. The fuel pump rosa
master is leaking fuel where the throttle linkage hooks onto the
pump. If i remove pump can I fix it or do I need to send it to a
repair shop to fix?
There's a couple of "O" rings in grooves in the throttle shaft.
NOT hard to replace if you keep things clean and are detail-oriented. If parts in that area get improperly assembled, the engine can "run away" at startup.
Only problem would be if housing/bushings are worn excessively.
