Btzj02
In the near future I plan to investigate whether I have a problem with exhaust valve(s). The tractor runs good but my neighbor is a Farm All mechanic from way back and he says it sounds like I have an exhaust valve "issue". I also would like to install adjustable tappets if my 8N51 doesn't already have them. I have been doing quit a bit of research on this Forum, The original shop manual and u-tube. I won't order any parts until I figure out what I have, and my neighbor takes a look, but I have run into information on the rotating Exhaust Valves that needs clarification.
My shop manual has a very involved process to set the rotating valves correctly and the two videos on u-tube that I have found seem to imply the new rotating exhaust valves just pop right in and only the tappets need to be adjusted. I do use this tractor at least twice a week in the summer and some of those times are a full days work!
Question 1: If I decide to replace the exhaust valves are the rotating valves preferred?
Question 2: Are the new rotating exhaust valves manufactured today such that they are as easy to adjust as u-tube implies?
Thanks for any info that will help me plan this project. JB
