Rottary Mower
What type of oil should be used in the gear box of a 5' rottary cutter? I don't know the brand. I didn't see any past discussion of it in the archives. Thanx
If you know the brand you might find the answer on their web site. Otherwise a SAE 80W90 GL-5 rated gear oil is generally specified. If I remember correctly SAE 85W140 GL-5 is what is more commonly available now a days and that"s acceptable.
I believe Mark may have a leaky seal in his mower. Most people use corn head grease when this occurs if they can replace the seal immediately and need to use the mower.
Corn head grease by itsself does not flow as does 90W. Your "Hog" might be a lot happier with a 50/50 mix of 90W and corn head grease. Mix it in a zip lock bag, cut the corner and slide it in.
