(quoted from post at 11:18:42 11/26/20) Hi. Searching for someone than can make a round fuel tank with recessed end caps and rivets on the long seam. OD is 7.5 inches, OAL is 36 inches. Thanks.
ould a piece of well casing with ends welded on it work for you? Not hard to build and very sturdy.(quoted from post at 10:18:42 11/26/20) Hi. Searching for someone than can make a round fuel tank with recessed end caps and rivets on the long seam. OD is 7.5 inches, OAL is 36 inches. Thanks.
(quoted from post at 20:17:13 11/26/20) Material is galvanized sheet around 22-24,as a guess. The rivets are blind flat, tank ends recessed slightly with an overlapping seam
then soldered. Its a simple tank but the shops i talk too loose interest when you mention rivets. Going to line the inside with a tank
sealer when finished just to make sure.
(quoted from post at 04:12:42 11/27/20) Send me an email. Email is open in classic. If in modern, take my user name and add @comcast.net to it.
