Russ from MN
Location
Bemidji MN
Recently someone mentioned spraying roundup in the fall to get a total kill of weeds. Does any one have any experience with doing this? What time of year should we spray in northern MN to kill the roots. We have been using generic roundup for 7-8 years with mixed results, it seems this time of year some weeds are hard to kill. Thanks in advance! Russ
Yes, fall is the best. Also many have fallen into the trap of believing "roundup" is the answer to killing everything. It's more of a grass killer. Stubborn broadleaves, like dandelion, may respond better to a mix with a broadleaf weed killer.
you're finding plants that are resistant to roundup, either from natural selection or they've always been resistant. You should switch to alternative product(s) for a while. A good plan rotates products to prevent weeds breeding resistance.
karl f
ps "roundup" means generics too in this message.
Try 1.25 qts RU, and .5 Qt 24d esther, at a rate of about 10 gals product per acre.
I just bout some glysophate 41% today for 9.95 a gal fronm a bulk distributor.
Gordo
It works well for certain weeds - like Canadian thistles. It is their nature to flow sap upward in spring, to feed the bud & seeds from that massive big root storage system they have.
Then in fall after blooming time, they send the sap flow back down, to rebuild the root system & store up for the next year. It is best to spray these blasted plants during this time, with a spray that translocates into the root system such as Roundup or Stinger or the like.
Canadian thistle is really just a special weed, it acts differently than many other weeds, need to treat it differently. Spray it in spring or with a typical broadleaf spray, and you only burn off the top of it; the root will remain and regrow.
To kill a weed in fall, or a tough one like Canadian thistle, you ne3ed to look at the label on your spray, and use a full, full rate, don't skimp. Fall weeds are bigger, have thicker coatings on their leaves & stems, harder to kill. But in some cases it is the best time to kill, even if it takes a full rate of spray.
--->Paul
