RTV900 Dynamic (engine) Brake
Bryson H
I'm working on my rtv900 because the dynamic brake isn't working. The dynamic brake is supposed to slow you down once you let off the gas pedal but mine will just coast. I just installed a new motor (same one), and now that's the only thing that won't work. I adjusted the transmission and gas pedal linkages but can't figure it out. I have the workshop manual for it but there's nothing for "adjusting" or "trouble shooting" the dynamic brake, anyone know how to solve this issue?
Kubota utility vehicle?
I'm going to check the high pressure relief valve on the reverse side to see if its between 3270-3840psi, will get back to y'all
Does it have a switch under the gas pedal?
My exhaust brake worked that way.
Vito
I checked the high pressure relief valve (backwards and forward side) at first they didn't reach the right pressure, I swapped them around to just see what would happen and it got me to the pressure I need but the engine brake still doesn't work... i'm out of ideas at this point so if you have any ideas dumb or not send them my way.
For what it's worth - ChatGPT - asked "how do you adjust the dynamic brake on a kubota rtv900". Got this reply -
Here’s a summary of what I found about adjusting or modifying the dynamic (engine/hydraulic) braking on a Kubota RTV900 utility vehicle — a caution up front: many owners advise not to tamper significantly with it because the braking effect is built into the hydrostatic transmission system, and improper changes can lead to transmission issues. Use this for reference, and always consult the official service/repair manual or a qualified dealer before doing work.
✅ What the dynamic brake is​
  • The RTV 900 uses a hydrostatic-transmission (HST) system coupled with gears. When you release the throttle/pedal, the machine transitions into a dynamic brake mode where the HST acts to slow the vehicle (rather than relying solely on friction brakes). nettractortalk.com+3ManualsLib+3TractorByNet+3
  • According to the workshop manual: after dynamic braking, shifting gears can be difficult because torque remains in the transmission. The manual says you must either press the brake pedal or pull the “VHT pressure release knob” to create a bypass circuit and relieve that torque, enabling smooth shifting. ManualsLib
⚠️ Adjusting / altering the “abrupt stop” characteristic​
Many owners complain the RTV 900 stops quite quickly/abruptly when you release the throttle. Some want to reduce that for smoother operation. Here’s what I found:
  • One forum says for the rear brakes (which are “wet” type on this machine) the only real adjustment is the linkage system; the wet brakes themselves don’t have a “brake shoe clearance” adjustment like a typical disc brake. nettractortalk.com
  • On the dynamic braking/abrupt stop issue: one expert said there was an optional update kit from the manufacturer for this model that reduced the abrupt stop effect. JustAnswer
  • On forums:
    “If you do decide to try adjusting it I have a 2 page procedure …” Forums Forums
    "There is a fix … have your dealer adjust the valve in the transmission … we did it to ours and you get some more free wheeling before the transmission’s back pressure kicks in and that is about half of what it was." TractorByNet
So yes—there are modifications/adjustments people have done, but they often involve internal transmission valve changes or installing an aftermarket “coast valve” kit.
🔧 Step-by-Step (general guidance)​
Here is a general workflow for checking/adjusting the dynamic braking / abrupt stop effect on the RTV900 (note: specifics might vary by year/model):
  1. Park the machine on a level surface, apply the parking brake, shift to Neutral, and shut off the engine. (Many service/adjustment procedures begin with this. ) messicks.com+1
  2. Inspect throttle pedal linkage and ensure the return spring works smoothly (sometimes the abrupt stop is amplified if throttle returns too fast or linkage is stiff).
  3. Refer to the service manual section for transmission bypass circuit / VHT pressure release:
    • The manual states: after dynamic braking, you can relieve torque by: operating the brake and pulling the VHT pressure‐release knob. ManualsLib
    • So part of “adjustment” is ensuring that knob/linkage is functional and properly adjusted.
  4. If the abrupt stop still bothers you, look into whether your unit has the “update kit” (valve or spring change) that reduces the braking effect. The mechanic in one source said “there was an update available when these were first released… the only way to address this is through the update.” JustAnswer
  5. If you proceed with a valve modification (either OEM update or aftermarket coast valve) be aware: altering the dynamic braking will change how the machine decelerates and might affect shifting, load downhill control, transmission loads, etc. Many forum posts stress that the built-in braking is a safety feature on slopes. Forums Forums+1
  6. After adjustment, test the machine in a safe area: check how it decelerates when releasing throttle, how smoothly it shifts from L→M→H or 2WD↔4WD, and verify there are no unusual noises or loads.
🔍 Key things to check / measure​
  • Check linkage play on throttle pedal and ensure smooth return.
  • Verify the “VHT pressure release knob” is operable and linkage is not stuck.
  • Check for a service bulletin or update kit for your year/model that deals with the “abrupt stop” characteristic.
  • Ensure shifting operation is smooth after you coast to a stop: if shifting is hard, that suggests torque is still in the transmission and bypass circuit may not be working. (Manual warns of that.) ManualsLib
  • If you’re using the machine on steep grades, consider whether reducing dynamic braking is wise — you might lose the benefit of the hydro-engine braking effect.
