I could use a portable welder around the farm but at the moment I can't justify the cost. I have an opportunity to buy a solid looking 25 KW Winpower alternator at a good price. It's got the power to run my Lincoln 225 Amp welder but I'm not sure what I will need in the way of engine control. Portable welders that I've used change engine rpm based on whether I'm welding or not. Can I just set the tractor engine to the needed rpm for welding and let it run at that speed? Or will I need someone on the tractor to change speed to keep the output of the welder within the proper limits? Thanks.
