Reading over the manual for my JD348, it says to feed the hay to the right side of the pickup. I read that as the far side - away from the bale chamber. This opposite the way I run my trusty NH68, which is feed it right against the left most of the pickup. Where on the pickup do you feed your JD baler? Wondering what the rational for feeding the RH side. My guess is it gives the auger time to orderly feed a constant amount of hay into the bale chamber vs big wads right at the bale chamber side - but just a guess.
Do you ever adjust the hay compressor that sits overtop of the pickup? Manual speaks to this, but really I've never knew anyone that tinkered with it on any baler, including myself.
The feeder forks - I think there are 5 holes in it for adjustment. Not sure which hole mine is in presently, question is which hole do you run yours? Or for you it is probably where it was when it left the factory and never gets any attention?
The 348 has bale case side tension doors. Do you run them in or out or somewhere in between?
My NH68 really makes nice hay at 540 PTO rpms. I plan on doing the same with the 348. Is that how you run your JD baler?
This 348 has multi lubber on the knotters. Not sure I like that - somehow I'd be concerned one fitting wouldn't get any grease and I'd have a problem. Those of you that have multi lubber on your baler, what's the good, bad and ugly about these?
Been spending a goodly amount of time pouring over any info I can get my hands on with these late model JD balers and it looks to me like the 336/346 balers are the pattern for the 3x7 and 3x8 series balers, even down to the sheet metal.
Fingers crossed on this 348.
Any info on a JD square baler setup and general operation is most appreciated.
Thanks!
Bill
Thanks!
Bill
