Rust frozen brakes
Mike N Mo
I have quite a few brake assemblies from styled A's that are rusted/stuck tight. I now need a couple for a project, so I'm looking for ideas on how to get them dissembled. Many years ago, I used the brute force method, but broke the "ears" off of the adjusting pins. I'm considering building a charcoal fire to heat them up. Thoughts????
Loosen up the drum nut and then put a hardwood block on a concrete floor and then hold it up and drop it straight down onto the block. Some of them you have to force them down onto the block a few times. They usually loosen up. It doesn't get them moving I'd soak in a bucket of diesel fuel for a week or so and then repeat.
Agree with the soak if acetone and trans fluid doesn't work. Have used lead hammer on loosened nut rather than dropping. Whatever works works!
Dropping them uses the weight of them to help get it apart. A trick an old timer JD mech. taught me.
MIke, I tried dropping them on the wood block already. I remembered you suggesting that many moons ago. I'll try soaking them in diesel for a while. I won't need then for a few months.
Won't hurt to let soak for a few months. I don't think I ever had any that stubborn yet. I have broken some break drums trying to move tractors with stuck breaks. Sometimes just a few taps on the drum will let them turn and other times it cracked the drum ! Amazing how easy some split. But the split frees them up. lol.
I have had guys tell me to put something frozen from rust into a running stream. My cousin put a 4 section rotary hoe into the creek and it worked. This time of year, you may have ice to deal with.
