Rust on hydraulic cylinders
FireWater
What are my options to remove surface rust from Hydraulic cylinder shafts (chrome ?)
they are for the aftermarket 3 point we want to put on. Thanks, Ed
Polish the the chromed rod with FINE emery cloth wetted with oil to smooth it so it will only slowly kill the seals, then keep it coated with Fluid Film or grease, to prevent further rusting.
I agree with bob emery cloth and oil take as much as you can and then run it after using it they will eventually polish up pretty smooth . Bought an old farmhand f11 loader that rods were rusted pretty bad but after several years running it they polished up nice
Run them for a year or so with the seals that are in the cylinders unless they really leak then you can replace the seals with new and you?ll be in good shape
I had a steering cylinder that got pits at the point where the front wheels were near center. I cleaned, filled with JB weld, then polished smooth. after four years it was still good. Filling it can stop seal wear.
