rustred/John Deere D
i just saw it. the crank is not that great and those engine never had 50 psi oil pressure .usually 20 psi was the going thing. and from what you say about using it for pulling... well thats the hardest thing on brgs.to lug them down. running around as a chore tractor she will last way longer.
IF my memory is correct...your engine is a four cylinder with only four main bearings.?
There were a couple of carcasses (MH 44 Diesels) in my district that had Brocken blocks....... piston knocked a hole in the blocks.
Always the same story....either #2 or # 3 piston..
Given the evidence on the bearing inserts,I suggest you place a dial indicator on the crankshaft main Journal between # 1 & # 2 piston...as well as the journal between # 3 & # 4....and rotate Crankshaft...
Also an outside micrometre to verify Journal size, as per the bearing shells were running on.
Bob..
