Rusty Pivot Point
Web Dawg
My blade won't pivot at the center point. The bolt that goes through is about 1 1/2 in dia and looks good, but must be rusted down through.
I've soaked it tons with penetrating oil, took the nut off and tried pulling the side on the blade on a rock and puching one side against a tree.
Any ideas?
You said bolt that goes through. Does that mean that there is a bolt head? If so how about a big 3/4 drive socket, breaker bar and cheater pipe? I've used about 6 feet of cheater pipe before. By the way that seat doesn't look very comfortable but the fenders look awfully nice.
Even without heat, a few good whacks from a 3-5# hammer (hold another hammer against the opposite side to help w/the loosening effect) will often loosen the rust in something like that and do less damage to the paint job.
Once it's loose, take it apart to clean and oil it properly so you don't have to do that again.
I suspect that you have bought a "farmerized" back blade.
It looks like the blade part and the rotating mechanism is from one blade and the 3pt mount is from a different one.
