RICK IN GA
I see there is a difference between the lift cylinder safety valve on the NAA and 8N and 100 Series+. This site doesn't show safety valve for my NAA. Are any of these others ok to use?
(quoted from post at 10:18:30 01/26/12) I see there is a difference between the lift cylinder safety valve on the NAA and 8N and 100 Series+. This site doesn't show safety valve for my NAA. Are any of these others ok to use?
on't mean to pick 'nits' here, but Rick, you asked about a "lift cylinder safety valve" & the 8N has a system over pressure relief valve (it would open by overpressure between the pump & lift cylinder), relieving both the cylinder & the pump. Whereas the NAA has both a hydraulic pump safety/relief valve (TOH gave you the number) AND it has a ram cylinder/lift safety valve (NAA984F), two separate parts. 638 is in belly of tractor hyd compartment and 984 is on lift cylinder/valve assembly attached to top cover.(quoted from post at 10:18:30 01/26/12) I see there is a difference between the lift cylinder safety valve on the NAA and 8N and 100 Series+. This site doesn't show safety valve for my NAA. Are any of these others ok to use?
id not find it listed on the YT site. The {C3NN984-A} 1955-64 Valve(Lift Cylinder Safety) is listed for 1955 - 1964 on another site, but I have no idea as to whether it will fit your tractor or not. Call toll free 1-888-355-9937 and those folks will be able to answer that question.(quoted from post at 12:16:57 01/26/12) I believe the one I'm talking about is NAA984F. For the later Series Fords they used NCA984F according to my Parts Catalog. Does this site have the NAA984F?
(quoted from post at 12:07:06 01/26/12)on't mean to pick 'nits' here, but Rick, you asked about a "lift cylinder safety valve" & the 8N has a system over pressure relief valve (it would open by overpressure between the pump & lift cylinder), relieving both the cylinder & the pump. Whereas the NAA has both a hydraulic pump safety/relief valve (TOH gave you the number) AND it has a ram cylinder/lift safety valve (NAA984F), two separate parts. 638 is in belly of tractor hyd compartment and 984 is on lift cylinder/valve assembly attached to top cover.(quoted from post at 10:18:30 01/26/12) I see there is a difference between the lift cylinder safety valve on the NAA and 8N and 100 Series+. This site doesn't show safety valve for my NAA. Are any of these others ok to use?
robably just re-use it. If you could find a way to connect a pressure source to it, you could see that it holds at <2700 PSI & relieves at 2700-3000PSI. Why are they "baffled'? Can't find number or what?(quoted from post at 16:40:09 01/26/12) I am surprised that this question has not found an easy answer. I called nnalert and they were baffled too. I just got off the phone with the parts dept from this site and they were baffled as well.
I'm thinking I want to change my question as a result of the responses. Can this valve be cleaned well and reused? I have no indication that it was a problem to begin with.
ow, you have me wondering which valve you are talking about??? First picture or second picture (lower left, next to supply tube)?(quoted from post at 17:32:30 01/26/12) At nnalert the 8N-638 looks just like it, but the other one NAA9** looks completely different and says it is only for 55+ models.
(quoted from post at 17:30:04 01/26/12) That's definitely what I'm trying to get my hands on whether I need to or notI just called my NH dealer and he said it was discontinued but put me in touch with a rural salvage guy that actually said he has one for $55. He said they're "Like Gold". :-0
Still think I wanna see whether it can be cleaned or if that is a bad idea. I was hoping that Zane would chime in here. I am the proud owner of a ZANE THANG.
hich of the 2 in my pictures above are you talking about, Zane?(quoted from post at 20:32:16 01/26/12) It is strictly a pressure relief valve. Does the same thing as the 8N 638 B in the 8n. It is not a check valve. The only check valve on the NAA is the back pressure relief valve and tube.
I have opened up the NAA valves and sometimes found a piece of foriegn material in the ball and seat keeping it open. Clear this out and it will be good as new if the ball and seat are not eroded. Over time the ball and seat can become eroded and cause leakage. A new ball of the same size can be used and I have taken a wooden dowel and vavlve grinding compound and resurfaced the relief valve seat on several relief valves with mixed results.
Zane
K, but down in the hole that you un-screwed that valve from IS the CHECK valve spring & ball. Might want to examine it too.(quoted from post at 21:06:44 01/26/12) Thanks JMOR It is definitely the NAA984F. It is in good shape with no noticeable corrosion. My back pressure valve you noted above moves freely, I took it out and cleaned it well. My control valve will just need to be cleaned up. The confusing thing is that the 8N model pointed out by Zane looks just like the NAA984F. My thought was.....same valve.....different model (The 8N version is readily available), but since no one is sure looks like ill save a few buck and clean and reinsert. Thanks again! Rick
