saginaw three point for m
rocklong
i've have a saginaw three point hitch ordered and in the mail, it isn't here yet but i mounted a two way valve and some quick couplers. I was just wondering if the way i have things mounted they will be out of the way to mount the hitch?
Unless they have changed something, you will be
just fine with how you have things.
Attached pictures are mine, as you can see its
been modified a fair amount!
ok it looks like it will work fine. Do u just have 90 degree street elbows on the top and bottom of the cylinders and r they half inch ports on the cylinders, i am trying to get everything ready so when it gets here i can hook it up and use it. thanks
Yes 1/2" 90 degree street elbows on the cylinders.
I have short hoses from each cylinder into a T
that you can kind of see under the PTO and then up
to outlets under my gas tank.
You could plumb your T directly out of your quick
connect and use slightly longer hoses down to each
cylinder from there.
yea that is what i planned on doing it should work out pretty good i think. thanks for the pics of your three point mounted on your tractor that helps out a bunch. a pictures worth a thousand words.
PTO pump will fit just fine. You will reuse your
horseshoe drawbar as shown on Saginaw website. My
drawbar is off a much larger/newer tractor and
fabricated to fit by previous owner. Not sure why,
but it was very nicely done. Your hitch also won't
have the large angle iron over the rock shaft
bolting down over the rear platform. Again done by
the previous owner for some reason but does make a
nice step. My tractor will also be getting a PTO
pump and loader installed as soon as I get time.
I was wondering about the piece of angle iron something didn't look the same as the website. I wonder if I will have enough side to side and down movement with the horse shoe draw bar on there it looks pretty tight in the pictures on their website.
I have a Saginaw, the drawbar is not a problem with raising or lowering. As to side to side, raise the 3 point above the drawbar.
Ok thanks for all the help! Hopefully it gets here this week it shipped on the 9th from Michigan it was suppose to be here Friday and something must have happend to the truck cause it never showed up. It's been sitting in a town about 3 hrs away for a week but they have to get enough stuff to come out this way. For $175 shipping u would think it would be a little quicker.
showed up today got it bolted up i just have to put a couple hoses on then give it a try. very well made and strong looking i am very happy with it and i haven't even used it yet.
I got it all hooked up and everything works great. Thanks to everyone for all the help in answering my questions. Here's a couple more pics I know they help when ur searching for something. Thanks.
