Satoh stallion s750d
Paprules
3 point hitch not working has set for some time and have flushed system and cleaned strainer several times power steering is part of hydraulic system and works fine also flow valve beneath seat was stuck and was able to free up. There is little to no information on this machine any help would be greatly appreciated.
This post was edited by Paprules on 09/08/2021 at 01:26 pm.
My brother had a Satoh 650d and it needed engine repairs. While we were trying to find parts to repair it some one
stole and the insurance paid him for it. That was the best thing that ever happened to it. He did not replace it. He
was trying to get parts through a Mitsubishi automotive dealer I think.
Paprules, are the three point arms up or down? If they are up you might try putting a little weight on them to see if they will go down. It could be that the work cylinder is stuck (this is inside the case). The other place you could have a problem is in the valving. There is a hold valve, drop valve (if I remember right it is behind the valve you turned under the seat), and raise valve. There is only pressure to raise the arms not drop them.
It's been over twenty years since we had ours so I'm a little rusty. By the way I helped (in a small way) prototype that tractor. As a young teenager was very interesting getting to work with the Japanese engineer! Ran the prototype til we got a production unit around 1978 I think it was. Last I heard the prototype is still running! Dad worked for the eastern U.S. distributor and the only person in the organization with a farm they could test it out on here. If I get the time I'll keep looking through dad's stuff for more information for you, haven't found anything on the Stallion yet, just the smaller ones. Paul
I am just scouring forums and the web for a line on Satoh Stallion S750 D parts. I don't need anything now but I know I will in the future. I have found a few things but it is difficult. Thank you!
That is so cool.
You can also search for the equivalent Mitsubishi. Satoh was purchased by them, probably in the very early 80s. I had a 630d, Bull I think they call it. Little loader and backhoe. Good tractor and I found electrical parts for an early 80s IH 235/255 worked on it. Even luckier, the IH dealer could still order them from Mits.
