Took the left side apart yesterday and found whole assembly coated with oil. Cleaned housing and actuator assembly, removed and cleaned disc and all looked very good. Wiped off inboard plate that bolts to tranny housing and found a half dozen cracks radiating out from bore, largest one at weep hole. Put it all back together and will fix another day. Brake works good now, til it gets soaked again.
If, and when you decide to replace those seals, here is a link to a place where I buy a lot of my bearings and seals, and this link will take you to the seal you need...
http://www.jbr17llc.com/skf-37390.html
I ran that part # at NAPA online... Almost $40.00 ea. It takes about a week to get the seals from these folks. I just replaced the ones in my 310B, and got both for less than one from a local supplier.
Also note the thread about the brake seal saver idea.., thanks to member "mEL". Wrap the splined shaft with electrical tape, and coat with oil. The seals will slide over, with no damage.. And with the price of these particular seals, sure don't want to ruin too many...!!
How much of the Lucas hub sealer would the tranny take with 11 gallons of gear oil? Don't mind the wrenches though, kinda what it is about.
