SC Case clutch still stuck
jhncp
I tried driving it up a steep hill on the road in 3rd gear and pressed the brakes a few times so engine was working hard but still won't release. I also tried chaining the crank to the steering rod and tried rocking backwards in 4th. I have all the pressure plate bolts backed off and tried squirting penetrating oil on the clutch. The tractor was sitting up in the hay mow for a few months with the hand clutch forward and always worked good.
If you were able to get to the bolts, take a butter knife and work it in between the clutch and flywheel all of the way around to break it free. Had to do that to a Oliver 1655 that I bought and the clutch was stuck
