sc compression ratio
CASE BOY
does anyone know what is the compression ratio on a case sc with 3 11/16 bore with high dome pistons.and how much can i safely mill off the head to increase the ratio.
One problem is the head may have already been shaved when it was rebuilt previously? There should be some sort of flexible material you could put on top of the piston and reassemble the engine with the old head gasket. Turn the engine over, remove the head and then measure the thickness of the deformed material. Might want to talk to someone at a machine shop.
