Schlemmer Replacement Carb SpringValve Drirection
yzr1
[color=darkred
Brain Fart Moment, Help Please:
I ordered a replacement carb for my Schlemmer Weber Carb and was dutefully moving the control arms on the throttle and carb over to the correct side of the carb and found that he new carbs choke plate and a little spring and valve on it. This is no big deal but I am at loss as to the correct orientation of the openeing.
Does it open inwords to allow suction to pull a minimum amount of air or, does it open outword to allow backfire pressure release in case of engine backfire. Since the original was just a solid plate, Im not sure its a game changer, but I was just scratching my head and admintting, I'm not sure on this one.
tku
][/color] :D
(quoted from post at 14:28:20 04/04/20) Not for back firing, It allows for air flow INTO the carb,,,,
Thank you for the reassurance. I put it that way and all seems well, but it has continually bothered me in the back of my mind ever since. Now I know, all is good. tku again.
" Schlemmer Weber"......that is a new one on me! But in the M/S carb, it opens to the inside such that one can not completely stop air flow with the choke.
