Schwartz frontend tierod assemblies
https://www.external_link/tractor/Schwartz-Wide-Front-Parts
Have to copy, and paste, in your browser. Site won't apparently allow a proper click on link.
I understand this site sells stuff and wants to protect their territory. I’m good with that.
For parts that this site doesn’t carry, it’s useful for us to be able to help each other out…
I believe you might be trying to link to that German beer cup place, stein- something?
I used my search engine ‘Schwartz wide front parts’ and came up with that site, and several others that suggest they handle some parts.
I thought I saw reference to parts in the s h o u p catalog a few years ago, but not sure any more.
Unless you want original, it may be possible to build new ones using ends from a late model vehicle. Converted a neighbors super a from the ball type tie rods to the modern style once. Got the arms from a used dealer but they did not have the tie rods. Could not find them. Took one of the arms to local auto parts store and matched a tie rod end to fit it. Got some heavy tubing and built the tie rods. Worked fine.
Aw Hell....................I looked at the parts in my links, and the one offered here. NONE OF THEM WILL FIT THE SCHWARTZ FRONT END.
You might have to go this route (I always make my own front end parts for this, and other problems).
70's model pickup truck tie rod ends will fit most older tractors. They're made of steel, so they're weldable.
If you want to expend the effort, you can do what wh suggested..........make one with tubing so it's adjustable.
You'll probably need a lathe to make an adjustable one.
I generally measure carefully,, and make mine out of solid round stock.
