Sears LT/10 surging
gonoles6100
I have a 1976 Sears LT/10 with a 10hp Briggs and it has trouble surging. I was wondering, what are the factory settings for the adjustments on the carb, i.e. 1/2 turn out. I like the tractor quite a bit, but the surging drives me crazy. Im thinking im going to take it off for a rebuild, but I want to know where to set the screws.
Good starting place is 1.5-2 turns out from lightly
seated for the main mix and 1 turn out for the idle
mix.
If you start it and it still surges badly, it could
be a dirty or gummed up carb or a bad head gasket.
I have a JD 112 that did the same thing. I adjusted the carb and then put some Lucus fuel additive in the tank and worked it hard for a while. It runs smooth as can be now. Then I did the same with my Troy Bilt tiller that was doing the same thing, it runs smooth now also.
