Sears ST 16,Carb.??
Joe 427
My tractor 16 hp one cylinder will idle for 5-10 seconds then start to die out then the throtle will open to wide open then start to idle fine ,then it will do it all over again
The most common cause of this series eng to surge/hunt for it's speed is plugged/restricted idle passages in carb body due to dirt/gum,you can try opening idle needle 1/4-1/2 turn,if that doesn't cure problem,remove/dissasemble carb,remove any brass plugs/welch plugs in body,soak in carb cleaner overnite & run a fine wire thru all passages you can find then blow out passages with compressed air,buy/order a rebuild kit from sears/local dealer & rebuild carb or see if you can find a new oem/aftermarket carb on ebay/online dealers.
Another thing to check is the throttle shaft for wear a very common thing on the Walbro LM series carbs. As Joe post there are carbs for that engine listed on e bay pretty regular also theirs a fellowing Ga that will sell you parts or will rebuilt the carb for you.
http://www.carbrescue.com/intro.html
