second attempt, torch cart
Tig
This is one of the torch carts I have built for work. The hose rack was built from a piece of rolled sheet metal
Other side of cart shows axel at the back of the acetylene bottle. This cart tips easy when it has to run over something that is above the floor with one wheel
Here you can see a lifting eye that we use to hoist the cart twenty feet to the second floor with an in house crane.
If this post works I will post two other carts that are in use.
Tig, when you post the two other carts just paste the address into the Optional Image URL box located below your message. Use just this part of the address. http://i677.photobucket.com/albums/vv132/JOB_KATH/100_0244.jpg Leave the
Thanks Crem, I am a little computer challenged. And probably a lot challenged compared to you guys.
I am not an expert either. I just work at it and try to make it work.
In photobucket I copy the address in the direct link under the picture that I want and then paste it in the Optional Image URL box located below your message
I do like it,,, been wanting to build one narrow so I could fish it tween my junk instead of taking a victory lap around the shop to get it were I need it.... I brought a small square cart from one of the traveling tool shows that has a swivel wheel in the front that you can press a leaver with your foot and it swings the wheel down so you can roll it around and of you want it stationary use your toe to pull it up,,, will have to look and see if I got a are can find a pix,,, I cut up the cart and put the swivel wheel on one end of my brake lathe so i could push it out side to blow it off,,, it would work well on your cart...
Are the hinged brackets that hold the top of the tanks the same on both sides? Is there a pin to pull out to open the bracket?
Yes Crem the band looks the same on both sides, there is a pin to pull out on both sides of the band.
