Second hand parts
07AKU
So I recently ordered some wheel bolts for my Massey 40 steering wheels and was told they are "not in the best condition" I pulled the trigger as they are pretty rare to find here and I had been looking for a couple years for these.
Unfortunately I cant seem to post images from my computer but to describe issue:
The shanks are rusted badly, in places over 40% of the shank thickness is missing and cratered due to what I can assume is a lifetime of abuse and all the threads need working over with a button die before a nut is likely to ever go on them.
One of the bolts looks as if it has been snapped and got a farmer in the field job to fix it.
I can weld up the shanks, turn them back down to diameter, work over the threads but the question is:
Is this safe? are parts for machines of this age (late 70s) always that bad? (the same bolts out of my machine are totally free of rust, pitting or thread damage I just wish I had them all)
And if these parts are trash, is it common for tractor wreckers to sell Iron Oxide to customers and call them parts?
Is this tractor in use everyday for hard labor or is it an extra tractor for lite work or just a
show tractor? You said you have to ability to weld them up, turn them down and rethread. I would go
that route without question myself. Chris
Are you talking about the lug bolts, Item Key # 15, in this drawing? If so, they are readily available new, no need to buy used ones. Just do an on line search for that part number. I would suggest confirming the thread size and pitch of yours, in case it has had a hub with different size threads installed in years past. 1/2"-20 and 9/16"-18 are commonly available at most dealers, farm parts stores and can be ordered at auto parts stores.
I should have asked, Where are you located that finding these is a problem?
As for posting pictures: Not always, but in many cases new users have to have 5 or more posts on record before the site lets them post pictures, due to site spam filters. Another option is to go down to the Site Comments Forum and ask YT Support for permission to post prior to that. You can try going down to the Test Forum and making several posts there, trying to attach pictures to each post. That may work after you make several, then post again here with your question. It may not work immediately after you get past the 5 posts, if not, you might try logging out and back in at that point. There is a size limit as well, I think it is 7.5mb per post, some phone pictures are too large and have to be reduced. Keep trying it will work soon.
Thanks for all the replies, I am attempting to restore the unit to full duty with a couple of mod cons like CB radio.
The bolts in question (sorry I still seem to be struggling with this upload thing) are for a split rim setup and have a large truncated square head and a fairly long unthreaded shank.
These bolts seem to do double duty as both a wheel wedge to hold the split rim to the hub but also to hold the split rim together hence my trepidation.
Maybe yours are different?
Looking up your tractor on the tractor parts section on this site it shows a half a dozen of them for $7.47
Hi
They are heaps different to this, think of a truncated square, or a square based trapezoid where the small end has the shank of the bolt on and said square is the head.
The spam bot doesn't like me trying to link any images either uploaded or from the internet, sorry to have to play 20 questions :(
The front hubs are cast iron units weighing about 40kg a piece and not those lighter duty units shown.
Good morning,
Where are you located in this wide world? Knowing that might help shed some light as to why there is nothing like the wheels you describe, in the parts books many of us look at. And why something we suggest might not be available in your area.
I have purchased new square head high grade bolts for John Deere rear wheel adjustment clamps from bolt suppliers, by using dimensions.
As you post keep trying to add pictures. At some point soon it will allow them to post.
Another thought, Are you looking at bolts that hold front wheel weights to the wheels, not the lug bolts that hold the wheel to the hub on the axle?
I'm having trouble picturing the bolt from your description. Best I can make out you're describing what's known as a plow bolt. Like a flat head for a countersink with
a square shank like a carriage bolt.
(quoted from post at 06:00:42 12/15/20) Hi
Make a few more posts and you will be able to add pictures.
(quoted from post at 07:36:24 12/15/20) 07 ..... any possibility you are needing something like this? Photos below. This has a 5/8" shank ....
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto67056.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto67057.jpg">
Very similar to this, yes, they have a longer body on the head with a circular relief in the top but pretty much those yes.
Nominal diameter of the shank is 14.2mm (my IMP is weak but I would say they are meant to be 9/16)
Length of the thread and shank is 100mm and overall length is
118mm +/- 1mm
Thankyou for the image because I couldn't even find a close reference on Google.
On my unit they hold the rim to the hub with is then bolted to the axle in a manner more normal to a car.
Very similar to the rears except there are no wheel wedges, the heads seem to do this duty and also hold the 2 rim halves together while the tire is inflated.
One side is pulled into a square slot cast into the hub and the opposing flat pulls on the inside edge of the rim, thru-bolted and the back half is held against a lip machined into the casting, washers, ofc, only on the nut side.
(quoted from post at 20:35:45 12/15/20)
Still have not told us where you are located.
Sorry, such a volume of information came at me so fast (thanks all! :) ) that I must have missed that one.
I am Australia, specifically Tasmania.
I am under the impression from doing a little more reading that the MF40 we have here is supposed to have some key differences to other versions of the MF40 from around the world and even among those my front steering wheels are even more uncommon than that. The machine holds a serial number of '203*' and was built just 2 years before the plant that turned them out was closed.
Buuut we are getting a bit off topic. Just how ratted out can a bolt holding all that static and dynamic load be before it becomes a safety hazard? I'm not overly keen on blowing something up with the steering wheels letting go, least of all, myself or others.
I would like to suggest you post your needs down below on the Massey Ferguson and Massey Harris Forum. Include your location in your post as well, as there are a few fellows located across the pond from us and nearer to you with a good knowledge of the MF tractors in that part of the world. I don't know how often they visit this forum. They may have some info/manuals to help you out that we don't have.
I see you have 5 posts now so you should be able to get a picture to post.
Still cant post images.. It would be so much easier that way.
Now I can, as said build up and turn down buuut just because I can doesn't mean I should?
Lots of general questions like do I "need" all those wheel bolts, I was given advice (and not taken :lol:) to run my drive wheels with only 50% of the mounting hardware.
I am just a man with a lathe a welder and a tractor and just enough knowledge to get neck deep in trouble and frankly split rims and rusty refurb mounting hardware doesn't seem safe (also I am not sure if it would pass the inspection for re-registration.. but that is more a local laws issue, but these laws exist for a reason?)
Lots of general questions like do I "need" all those wheel bolts, I was given advice (and not taken :lol:) to run my drive wheels with only 50% of the mounting hardware. The requirement for this machine regardless of make or model is to be as reliable as possible as it will be doing hundreds of hours of work thousands of dollars from the nearest workshop and I don't fancy having to leave my machine in the middle of a "swamp" for another few years while I track down parts (if they happen to be "the wrong parts" that break) or God Forbid, need an air lift, or worse yet a pine box because of a failure.
What sorts of metal are old mounting studs like this made from?
I mean my good bolts still have casting flash on them which in my limited experience is a good sign I cant weld it to a standard to which I would trust my life or the life of others against I do have 2 "practice" or "spare" bolts because I always over-order due to paranoia and 'they don't make 'em anymore" factor so I can do very limited testing but have no idea how to really.
I am just a man with a lathe a welder and a tractor and just enough knowledge to get neck deep in trouble.
(quoted from post at 21:51:40 12/16/20) Still cant post images.. It would be so much easier that way.
Keep trying on the pictures. There is a size limit of 7.5mb per post, as I remember it. Some phones take large pictures than the or trying to post more than one may exceed the limit. Again, try posting this on the Massey Ferguson Forum.
If these hold the rim together, as well as mount the wheel to the hub, you do want to be sure they will hold.
Well it finally happened! we can finally get an image of the offending hardware. The bottom 4 are wrecker supplied units with the top 3 being some of mine for reference (I just wish I had a full set in that condition)
