Sediment Bowl Assy
Joe Pro
Ok guys, on MM U302 there has been a slight gas leak at the sed bowl. So i recently checked it out and determined that it was coming from the nut that seats the shutoff valve. Are parts avilable IE new seals or where can I get a new assebly.
Also and tips to remonve the assy from the tank, except be easy with it.
The unit will usually come out of the tank without too much trouble. If it were mine, I'd replace the whole thing. DO NOT get the ones from the "big box" tractor store, it will leak worse than the one you have now! BTDT Go to www.external_link.com The units they sell are top notch and the guys that run the business are helpfull folks.
I've used their units and it's just install them and you are done. And at half the cost of the ones at TSC.
You might try just tightening down that packing nut a bit first. Might not solve the problem, but then again it might, and it"ll cost you nothing to try.
Joe, it's down at the bottom, under MISC. PARTS
Both are $22.50, same units except the glass bowl is longer on one. Both flow the same amount of gas.
Ask for Mark or Victor.
