Sediment bowl packing
Bill in IL
Have a small drip from the sediment bowl coming from around the shaft for the fuel shut off valve. I have tightend the nut about all I can so I think I need a new packing.
What do you use to make a new packing for those things?
A small diameter cord string should get you out of trouble. 1/16 diameter stuff like kite string maybe. Just for good measure you could treat it with spray graphite, wind it on there allowing enough to get good thread engagement on the packing nut. mEl
The old-timers used a piece of cotton string from a mop drawn through a bar of soap to lube it up.
Graphite faucet stem packing from the plumbing department at your favorite hardware store or home improvement store works great.
A very small O-ring works for me, I think its
universal size 005 or 006, and use a hydraulic
grade O-ring, not a water system O-ring from
the hardware store. (If your hardware store
doesn't know--go someplace else)
I stock a 100 size assortment of hydraulic/fuel
compatable O-rings in my shop
