I have a 49 Ford 8N. After removing the hood, I reattached the fuel line and cleaned the glass sediment bowl, installing a new gasket. I used NAPA gasket 730-9506. It leaks around the gasket.
Now I cannot get the gas to go through unless I leave the screw (bottom of glass bowl) VERY loose. If I tighten up the screw, there is NO gas going into bowl after I turn the shut off valve on. I have about 3 gallons in the tank. I cleaned the old gasket material off the rim thoroughly. In all cases it still leaks around the gasket.
Is this an indication of a bad bowl assembly and should I replace the whole bowl assembly that screws to bottom of the gas tank?
I could find nothing in archives, other than other people had gasket sealing problems.
Thanks for any replies.
GordyMN
GordyMN
