Seeding hay for some one questions
Dave from MN
A guy wants me to seed hay (grass mix) on his land. Very light soil. He disked the heck out of it but it is very rough. What wwould I charge him? Provided he buys the seed. Also, since it is very light soil I say it should have a cover crop , like oats. So he says I can put an oats crop in when I seed it for him into hay. I dont think he would get a good stand if I plant the seed with the oats, no grass seeder on the drill. I thought i would drill in the oats the rate I need for a crop, and then a day later seed the grass mix with a brillion seeder. Also... what rate hay should be seeded, he says he doesnt want to spend alot, one place told him 10# an acre, one place 25#, I was thinking anything from 18-23 depending on what seed we end up buying. The guy is getting all antsy as he wanted it done right now. I still think a fall seeding would be better. He also didnt want to put down fertilizer,(cost), but I feel he needs it or it isnt gonna take off good. What I recommened he dowes is have the coop seed it( run a packer, air seed it then run a drag over it) the coop mix has a rye grass that takes off to green up fast and hold the soil. That would cost $52 seed, $54 fertilizer, and $6.50 to air seed, and they will stand behind theis mix and application method. So about $113 an acre, plus the cost to have someone run a packer over it. I would like to help the guy out, but it is getting frustrating with how quick he wants it done, and he initially sounded kinda surprised that he would have to buy the seed. His biggest issue is he wants it established quick so he doesnt have any green acres( reduced ag tax rate) issues. Can one share some advise, cost recommendations?? Thank You.
Our soil here is different (heavy clay/loam), so that may change some things... I always plant my hay (alfalfa, clover mix, or whatever) at th esame time I seed my small grain (usually oats). Never fertilize my oat ground, just manure and starter fertilizer for corn. I get a good stand at 10#/acre from a Brillion Sure Stand seeder, although a lot of guys go a bit heavier, 12-15#. 25#/acre sounds like someone trying to sell alot of seed. As far as what to charge... I'd think somewhere in the $6-8 per acre, per trip range should be OK, or maybe a little more. Drilling and cultipacking aren't heavy jobs using a lot of fuel, but you need to get a reasonable ammount per hour for your time, plus fuel and equipment use. I'm assuming around 5 acres per hour at that rate.
I always seeded straight alfalfa, never grass, so the rates I used may not apply- would go with the dealers recommendation. Pulling a packer reduces the seed needed by at least a third. Is the Brillion the same width as the drill? Then pull the Brillion behind the drill- once over. He should understand that there is no rush- too cold for the seed to germinate. Alfalfa germinates much better late in May than now, grass may be similar. I don"t understand the rush for Green Acres- I think he is largely uninformed about a lot of things. With a 10 foot drill, you can do about 3-4 acres per hour. Is this land that you rent? It is customary here that if the owner wants hay seeded down, he buys the seed. If you buy the seed, he needs to guarantee you the land for at least three years- customary. If he"s so concerned about cost, why doesn"t he rent the needed equipment and do it himself? Plenty of dealers willing to do that. Might be a good learning experience for him.
We,ve always pulled the Brillion Seeder with the drill. One trip job done! Always make several trips over the fields with tine harrows with roller baskets to acheive a fine tilth and smooth surface. Oats make a great cover crop. We seed straight alfalfa. A good growing year we've baled a good crop of alfalfa after combining the oats earlier in the season. We have honeyway loam soil though.
Having planted hay for 35+ years, I would run
from anyone that wants a quick, cheap hay stand.
In my early years every time I got tied up in
one of these deals there were 2 pxxssed off people
I seeded some rye mix into some very poor soil last year for a guy at almost 20 lbs an acre near the end of May. It was patchy. I used a brillion sure stand using the big seed box. The seed was small enough it ran out when stopped.
The guy had stripped the topsoil to use elsewhere and was planting into the clay till that was left. I disked it 3 times before and picked ledge rocks as much as I could.
His stand was patchy, I never got paid. Two unhappy people.
