Seeking Tim S's Knowledge
I just split a 4010 to replace the pin. Would like to make the PTO 540 only. Read through the forums, but I could never find where Tim S shared his knowledge. The closest I got was "John Deere 4010 PTO on 5-2-17. At the end, NY 986 said when Tim came back he would enlighten us, but he never did. Is this knowledge still out there?
Ooh Yes I'm still here,, It's kinda hard to explain how to do it,, what it mounts to is removing the 1000 gear and using make shift spacers block the shift collar into place on the 540 gear and make sure it can't rub the trans case on the back side, remember to leave one splined washer inside the collar that you use on the gear,, i will try to find some pics... I can't seem to find the pics right now Darn it,, I will walk you through it when your ready.... ( [email protected])
