Seen on the road
jon f mn
This is one of those pics that just keeps getting worse the longer you look.
Yes I know about taking pics while driving.
What am I missing?? The only thing I'm seeing wrong is, I was expecting there to be an Arkansas plate. LOL. Just kidding.
he needed the extra height. and safety chains are hooked up. if them angle irons are mounted to the frame and all welds good i would pull it also. its not a heavy load. better than a lot of junk on the road.
(quoted from post at 20:47:09 10/12/22) Look very closely and follow the hitch from the truck receiver to the ball. Has nothing to do with the angle irons.
I did, as and near as I can tell, the ball shank goes thru a hole in the horizontal leg of each angle iron. Sandwiched between the shank nut and the upside down drawbar.
The vertical leg of each angle iron being cut back to accommodate.
And I would bet the other end of the irons are bolted down via the bed bolts or thru the bed and into the frame.
i followed it very closely before posting. i still say the angle irons are bolted to the bottom of the ball. then i presume he has them bolted to the frame. they sure would not just be sitting that way driving down the road! its a well thought out poormans hitch.
You guys need to start keeping your stories straight. If you saw him using this to haul a small tractor or even a lawn mower you would all be calling for YT DOT and Barney. Now since it is just the trailer it is alright. I don't know some days. And nobody has said BOO about the tool box just setting there with nothing to keep it from bouncing out. Just the two angle irons to keep it from just sliding out. Then the next semi you see going down the road with something less than stellarly tied down you all complain about it. Does the contraption look like a cobbled up arrangement yes it does and unconventional. Yet it does seem to work, and I'm guessing he is just getting it home to make whatever he thinks will work for him out of the trailer.
Had to take a second third and 4th look at this hitch setup
Seems that its all removable
First look and its scary but if you study it its a very well thought out extremely heavy duty hitch setup
It attaches to the trucks receiver and bolted to the trucks bed. Im assuming its bolted correctly as you cant see it from the picture.
Very unconventional but think it should have a much higher capacity than the receiver alone
Good Thought provoking picture
(quoted from post at 09:23:47 10/12/22) he needed the extra height. and safety chains are hooked up. if them angle irons are mounted to the frame and all welds good i would pull it also. its not a heavy load. better than a lot of junk on the road.
Chains are not crossed.
May be better than using the factory hitch with a riser insert. Even on my HD2500 the tongue weight was partially supported by the bumper. I have a tri axel I haul hay on, and I bent the factory hitch. I replaced it with a hitch with a 2500-pound tongue rating that is not attached to the bumper.
