I have a 4000 4 cylinder diesel (1964) and I adjusted the bands, and changed the fluid. The tractor runs and shifts great, however after the band adjustment, it would hold on a hill in part. I have heard the procedure is different on different select o speed transmissions. I went by the manual, however I am not sure the manual matches my tractor... How different are the procedures?
Also, what is the normal operating temp of the transmission? After mowing a field, I can't hold my hand on the side. Guessing it's running about 135-150. This sound normal? Thanks guys
I see guys talk about direct drive and overdrive? I thought you have gears 1-10 and thats it. Can someone explain this?
One more thing, the 3 point works good, however when holding a load in the air, I notice the arms "bouncing" or "searching" slightly, like it drops an inch and goes right back up. It holds a selected position fine, guessing piston oring?
