Select-o-Speed shifting precautions
Marto
I have a ford 3000 selecto-o-speed 1966. My neighbor told me if you want it to last (other than the normal fluid and filter change) always start out in 5th gear, or higher. Is there any logic to this?
Yes, Fith and anything lower are for very low speed work only. With no load I usually start in 6. The owners manual recommends starting off one gear lower than the work will be done in, and then shift up. Starting in first would be pointless and would put unnecessary wear on the trans and linkage.
I never start out in any gear higher than 5th. My 3 cylinder 4000 S-O-S will pop the front wheels off the ground if I start out from a dead stop in 6th gear without any weight on the front. Granted all I use it for is brush hogging and pulling small stumps, so I never want to go very fast anyway, but if I want to run it in 6th or 7th gear I start off in 5th and then shift up once it's moving.
No! There's not. You can start that transmission in any speed you wish to start it in without undo wear. If you're doing light work, 5th might be a good one. I'm not afraid to start them in 6th if I'm hitting the road, or 1st if I'm doing something heavy. If your inching pedal is working properly, you'll be good no matter where you start.
