Select-o-speed
My 1966 Ford 4000 recently is developing problems with getting the gear shift lever out of "Park" position. When changing gears there is some greater than usual resistance, but getting it out of park is the real issue - need help.
I would start by asking if you have a good service manual for it. When I got my SOS a few years ago, that's the first thing they would ask me. I've had my SOS apart a couple times and there are a few tricks to know and the manual is the best way to learn. For your problem, I would first look at the selector and cable. Disconnect the cable from the trans and see if the stickeyness is just in this area. Some brake cleen and grease may free things up. Otherwise you may have a spool valve(s) sticking which means the top cover must come off to look at the control valve
got your email! Will reply here. I second what Mike said. With the appropriate repair manual, remove the shifter. Find out if the shifter is the problem or the control valve in the transmission and post back with your findings.
