Self propelled windrower (JD 800)
flying belgian
I'm putting new drive tires on. They are power imp. tires which means they have bar lugs like a rear tractor tire. I wonder if I should mount them backwards. Now hear me out. If you have ever driven one you know you drive forward in wet field until you sense you are starting to sink. Your only hope at that point is backing out. You can never continue through wet spot. So wouldn't it make sense to mount tires backwards? Anxiously waiting for opinions. Thanks.
Ya , I have thought about that too, but usually if the wet spot is that bad, you are sunk and need a tow. If you do this evil thing, and get into trouble later, let us know if you thought it helped get you out. I have Diamond tread tires on one swath, and it can get stuck on wet grass.
My case is similar and by the time you notice your sinking it's too late anyway. One side of mine has reversed tires on it and I don't notice any difference from side to side.
Mt buddy has the front tires on 2 of his hay feeding tractors backwards. Says they wear better on blacktop roads and will back away from hay feeders better. I'm not going to turn mine around.
My 800 with the 4 front tires seems to walk through anything, compared to the old owatonna with basically snow tires on it.
Ive heard of putting the tires on backwards on combines and such, so its not a crazy idea.
Paul
(quoted from post at 15:21:03 03/25/21) I'm putting new drive tires on. They are power imp. tires which means they have bar lugs like a rear tractor tire. I wonder if I should mount them backwards. Now hear me out. If you have ever driven one you know you drive forward in wet field until you sense you are starting to sink. Your only hope at that point is backing out. You can never continue through wet spot. So wouldn't it make sense to mount tires backwards? Anxiously waiting for opinions. Thanks.
Keep the final drive chains tight on those . And the lower slide adjustment on the Draper canvases loose .
Main problem with getting stuck is that some operators have the springs relaxed on the lift cylinders and are pushing the entire weight of the platform across the field on the skids .
Adjust the stops on the springs so most of the platform weight is carried on the wheels when the platform is on the ground .
JD sold a bunch of those 800s way back in their day and I don't ever recall seeing one with the tires reversed. I don't think I"ve ever been able to back my 2360 out of the mud once I get into trouble. I have the huge fat turf tires on it so they are good right to the point when they start to slip. Then its pretty much over.
Some operators manuals say to put the front tires on a mfwd on backwards for that reason if you have a loader on
(quoted from post at 12:21:03 03/25/21) I'm putting new drive tires on. They are power imp. tires which means they have bar lugs like a rear tractor tire. I wonder if I should mount them backwards. Now hear me out. If you have ever driven one you know you drive forward in wet field until you sense you are starting to sink. Your only hope at that point is backing out. You can never continue through wet spot. So wouldn't it make sense to mount tires backwards? Anxiously waiting for opinions. Thanks.
My understanding is the tires have the same traction going both forward and back. The chevron pattern is there for self cleaning. That is why 2wd combines with chevron pattern on the back tires are mounted backward - to clear mud better. So I do not think you will see an advantage either way.
