serial number 9n cant locate
solin777
My boss just got what I think is a 9n but I can't find the serial number. I looked where the head meets the block on the left side and there is no numbers at all. I even removed the paint to see if they were painted over. I found a number by the starter but it doesn't begin with 9n. I know its either a 9n or a 2n because it has a three speed transmission. Any help is appreciated Thank you
If you are looking at the correct flat spot below the head and to the right of oil filter cannister, and there is no ser. number, you could have an 8N Industrial Engine.
There should be a "plate" on the block that I believe was located behind the block below the head...
Is the distributor on the front of the engine or the side....side mount would indicate to me a later 8N engine was put in your 2N or 9N..
Tim
There is no plate or anything on the back of the block.
The distributor is on the front.
When I went to check for the plate on the back of the head I noticed the engine has always been red but the rest of the frame and the oil filter and starter were painted blue at one time and then were repainted to match the engine.
With that said it leads me to think the engine has been replaced.
If you have time, go to the archives area on this site, and there is a lot of info, some with pictures on the Industrial Engine...
It is very common to find these tractors that have been worked on and re-worked over the last 60 years that have parts on them from 2N"s, 9N"s, and 8N"s...
The one your boss has is probable one of these "mutts" or "franken--N"s" and will probably continue to work for him as it did for its previous owners.
Tim
Possibly has a replacement engine. I beam radius rods will narrow it down to pre '44. Solid iron on the axle trumpet where the fender bolts are says 9N. On the 2N's they were open. Lots of differences on the dash - 2 piece dash is 2N, one piece alum dash is early 9N. For more info check out John Smith's web site.
John Smith
There are date codes in some of the castings but you would need to have the info as to how to read them. The 9N has I-beam type radius arm and the 2N has tube type. Also a 2N has a lot of casting numbers that will start with 2N like the ones on the rear axle housings
If you lay underneath it the hydraulic pump will have an actual date on it. Of course it may not be the original pump.
