Serial number info
caseman68
I have had a HD6G for several years but wasn’t quite sure of the exact year . I think the serial number reads 4298 and I see another number that reads 92945 .
I also have been having diesel leak into my oil. I figured it might be the seal on the injector pump but wasn’t for sure how hard that is to replace . It’s an american Bosch PSB.
The serie number should be on back rear housing right side and about fuel in oil if he ben long time not running you better just loosen the oil drain plug until all fuel is out and tight the plug and start the machine he could be oké and seal should be between the injection pump and governor
