sh Carb overhaul
VaGasman
When overhauling SH carb how do you get the main metering seat out?
also how do you get the idle metering jet out of carb?
Main metering seat? If you are talking about the venturi, it will come out easily when everything is clean, as in soaking it overnight in good carburetor cleaner. IF you can find such a thing anymore. There are other ways to remove that venturi, but it is very fragile and no longer available, so don't break it.
Gentle heat, gentle heat, and more gentle heat .... in Momma's oven or barbeque, then more heat. Then a proper sized removal tool.
