SH CArb questions
GordoSD
Rusty Farmall shouold nail these. Doing a carb on a very late SH. The bolts that hold the two halves together are hex head with the center dot and three hash marks going to outer edge. Are these correct? All I've seen are the tall head screws.
Venturi is 23. Is that correct for flat top pistons?
IT ran OK before I removed it but the heaviest load I ever put on it was a hay rake.
Gordo
Gordo
I have never worked on that carburetor but it sounds like someone has replaced the screws with grade 5 bolts.
Should probably have 12x24x7/8 screws.
And as for the 7/8" length they may be very hard to find.
Get 1 inch and cut them.
If the bolt head looks like this, IH used them.
