sharpening a brush blade for a trimmer
riverbend
Location
Delano, MN
I was given a non running trimmer / brush cutter. It runs now but how do you sharpen the blade ? Is it set like a handsaw or filed more like a chainsaw ?
Greg
That looks like a formerly carbide tipped circular saw blade. That will be quite a bit of grinding to cut a throat where that notch is. You can do it with a bench grinder, and adjust the set by laying the blade on a piece of pine, and punch every other tooth. That will be plenty of set for a brush blade. If you had one lying around, you might be better off with a standard blade, much easier to sharpen.
(quoted from post at 14:52:44 08/09/22) That looks like a formerly carbide tipped circular saw blade. That will be quite a bit of grinding to cut a throat where that notch is. You can do it with a bench grinder, and adjust the set by laying the blade on a piece of pine, and punch every other tooth. That will be plenty of set for a brush blade. If you had one lying around, you might be better off with a standard blade, much easier to sharpen.
''That looks like a formerly carbide tipped circular saw blade.''
On the other hand, do you suppose it is made that way, sort of the circular saw version of an anti-kickback saw chain?
A possibility?
That looks similar to my Stihl Chisel Tooth blade I have for my trimmer/brush cutter. I enlarged your picture and I'd say it's not carbide tipped. You sharpen it with a chainsaw file. Find the size file that matches the coping of a tooth. Teeth sharpen on alternating sides and like any circular saw blade, the teeth should have some set.
I have sharpened a few on a chainsaw chain grinder with the approximate radius wheel on it. Its hard to get as good an edge as original because you are holding the disk up to the stone freehand.
get the small hand held sharpener,.. work like a dam. use it all the time to sharpen chains.
Somebody tried to cut a rock with that one. I have a saw just like it. As others have said, sharpen with a chain saw file or grinder. You will need to take a bit of material to get a sharp edge.
We have a Stihl, and a lot of rocks, so I took a carbide 7 1/4 skill saw blade and made it fit. I knocked out the diamond bushing and filed it to 25 mm round, it works great!
I have a Husqvarna brush saw and do the same thing but use an 8in carbide table saw blade.
With the diamond bushing removed it takes very little filing to make the blade fit the hub. New blade from Home Depot costs me about 1/4 of what they get for a new blade at the dealer.
I ended up sharpening it like a chainsaw. It is going to take a while to get it right. The sharp edge of the bevel was on the inside of the set. I do have a bunch of old skilsaw blades...
Thanks for the ideas and help.
