Sheared Flywheel Ring Gear Locating Flange
OldFart187
1953 Ferguson TO30
Location
Somers, CT
On my '53 Ferguson TO30, the pathetic thin shoulder locating the ring gear on the flywheel was found in pieces in the bell housing although ring gear was still in position. I'm guessing that 70+ years of being whacked by the starter pinion fatigued the poor thing and sheared the shoulder off. It seems to be ok for now but I've read about another owner who's starter no longer engages. Should I split the thing again while it's still on blocks or plow ahead and hope?
If I do decide to do something, is there a preferred fix other than buying a new or used flywheel? Some have suggested skip welding which I can do with my stick welder but preheating with a torch or in my wife's oven would be a pain.
Any thoughts?
Been reading old posts on this. Skip weld, tapped holes at the interface or washer clips seem to be the suggestions. I'm leaning towards tapping 6 to 8 1/4-20 holes in the rear face of the flywheel about 3/8 from the OD and use 1/4" thick rectangular washers. The washers would stick up past the OD about 1/16" and stepped to locate the ring gear about 0.070 forward of the rear face. The clips will be weight matched and attached by grade 8 bolts installed with Loctite 271.
Any thoughts?
Hi Oldfart187, you might get more thoughts by posting this in the Ferguson section a couple of forums below this one.
Thanks, I did that. My neighbor has a Ford 9N he put a new ring gear on 20 years ago. He said he doesn't think there was a shoulder and his still works fine. Mine lasted 70+ years and even though the 0.070 lip sheared off, the ring gear has only moved part way to the back. He convinced me that it's unlikely it will move much more in my lifetime.
Running the 6v starter on 12v produces 4x the pinion impact force and torque. No wonder ring gears get knocked back. Resistors that can handle 300a for hard cranking are huge and expensive, using two 6v batteries is expensive and clunky. Long skinny cables will melt. Looks like the only good solution is a 12v starter for $300. Ouch!
