sheetmetal painting question
superhguy
I have my restoration project together and running sweet now I am finally painting the sheetmetal. I have it stripped to bare metal using wire wheel and sandblast. Has some rust pits and a few dings. I"ve put a coat of epoxy primer on, now plan to use some body filler on the dings, glazing compound on the rust pits, sand it down nicely, apply a coat or two of laquer based surfacer, sand, then apply another coat of epoxy primer prior to topcoat of urethane with a hardener. Anyone see any problems with this sequence? how long should I allow the body filler to cure before applying the surfacer and same question regarding the epoxy over the surfacer? Also how long should the topcoat cure before applying the decals? Thanks for the help.
Use the body filler on the dents and the deep rust pits, do not use single stage (no hardener)glazing compound at this time. Since you are using a urethane topcoat, use a urethane surfacer over the epoxy (both require supplied air for breathing). The lacquer surfacer is ok IF you do not have deep scratches that it can shrink into. Use 3 coats 5-10 minutes apart, sand smooth and repeat if necessary. You can use glazing putty to fill defects such as pinholes in the body filler, usually before the surfacer. You can also use it over the surfacer for very small depressions that the surfacer didn't cover, however it is best to use body filler on these. Do not put topcoat directly over glazing putty (IMO), put surfacer over it and sand. You will see that you need additional body filler after you get the surfacer on. I use surfacer as my "guide coat" to see if all is smooth. You need to put epoxy over the body filler first because you will be down to bare metal when you sand the dents, you need at least 80 grit. I would put the last coats of surfacer over the whole thing, then sand and apply the topcoat. You can put epoxy over the final surfacer if you want to. But, be sure you use epoxy over any bare metal caused by the repairs, then surfacer. I have put epoxy/surfacer over body filler on the same day, more often the next day or later. It does not shrink that much, at least not for me. The MP 170 PPG epoxy I use can be topcoated in 30 minutes. This isn't worded very well, ask further if confused.
